Do the trigger settings translate over from V2 to V3 exactly the same? See attachment of my V2 settings and V3 settings for triggers. Mainly worried about the CAM2. Is Prim Trig Tooth Range now Primary Teeth Window correct?
Please post scope from V3 I will advice according CAM #2
Attached is my cranking scope from V3 software. Can you advise for CAM #2 settings? Thanks
scope_202488_1334.emubscp3 (607 Bytes)
