Launch control v3
Does anyone have launch control working? I tried using it but it doesnt lock into rpm target I have set and just goes into rev limiter. On version 3.028 it briefly staid on the target but then went to limiter. Just wondering if its setup problem or some bug
the launch control is very old feature and seems to be testes very wellif you publish log and calibration I can take a look
Here is the map and log. testing lc is towards end of the log
launch control test map.emub3 (61.3 KB)
launch control test.emublog3 (2.4 MB)
I still have not been ablo to use the launch control, but flat shift and rolling launch control are working just fine. So could there be something wrong with my lc setup?
I’m sorry I didnt review your project and log yet.
Please give me one day more.
I check your logs, project and code.
There was a bug made when Flat shift was implemented (flat shift overrides fuel cut settings from LC).
Here is a link for fixed 3.031 version :
https://www.dropbox.com/scl/fi/xw21zwpuxya18ils9myfe/emuBlack_3_031_LC_FuelCut_fix.zip?rlkey=5ct41avoifuuyxm4rdty3216t&dl=0
Please let me know if it helps. If not please check if spark cut is working.
that link goes into drop box and says something that cannot support file format
download the file first on your drive qnd upak the firmware. then upgrade the firmware
Got it thanks. Will test soon
still does nto stay at the targets.
lc test 2.emub3 (61.4 KB)
lc test 2.emublog3 (44.9 KB)
Are you sure you have upgraded with the provide firmware.
Still there is no fuel cut present.
I’m not able to test on the real hardware my correction, but it seems very straightforward
I tried to upgrade the firmware again but still no cut.
