Hey guys, I’ve been messing with v3 and given up as I cannot get the car to fire.
I’ve made numerous posts on here, all of my settings seem correct,
Only thing I just now noticed is in v2 the injector trim is set to 100%,
in v3 it wont go past 50% not sure why.
It doesn’t seem I can get the car to synch either.
I have my v2 map which works perfect attached, as well as v3, and a v3 scope.
Can anyone give me any suggestions?
0% on injector trim in V3 is the same as 100% in V2, be careful that you aren’t flooding your cylinders. The car won’t start if it won’t sync, try disabling cam sync and seeing how you go. This points towards incorrect trigger settings, I found the trigger settings changed from V2 to V3.
Yea I am certain my trigger settings are wrong, but from what I can see I have the information transferred exactly as it can read from one to the next, I can’t see any reason why I am having this issue.
My only hope is that as V3 spends more time someone else smarter than me will encounter the issue, or maybe they will make a translator from a v2 map to v3
Thanks Greg,
I did read the offset one in the help section shifts the firing order on v2. I tried to adjust the firing order in v3 with this information but I wasn’t certain how to sort it.
So on v3 what should I do with the secondary trigger?
nothing on secondary just primary form tooth 0 to tooth 1 not zero on v3
coil offest work per event so you have change so if is set 1 is shifting coils by 180deg. so by adding 1 tooth on primay adding 180 deg
On the scope you had a sync and also spark and fuel. The problem was cyl offset as Gred wrote.
You changed somethig and it doesnt sync anymore.
Please post you current base map and a scope from cranking.
I’m not sure why it won’t synch anymore the only thing that I changed from that map was the ignition outputs going from 1-2-1-2 to 1-22-1 as I was instructed to do.
My current base map is attached but I do not have a current scope. I tried to scope this morning but it didn’t work
So I switched back to 1-2-1-2 and actually got the car to fire, but its very clear timing is way off the mark,
I know base timing is still right because as soon as I got back to v2 everything is perfect,
Here is 2 scopes. scope_2024828_1010.emubscp3 (584 Bytes) scope_2024828_104.emubscp3 (557 Bytes)
this is the most current map,
Ign settings are set to 1-2-1-2 on this map, which is the same as the attached new scope v3 new map making.emub3 (60.8 KB)
Would not fire this way,
However I left it on sequential ignition and changed everything else back and it did fire and ran easier than before. But is extremely rich and out of time
