I couldnt figure out, how the spark cut percentage is defined in V3 when you configure Launch Control.
Can you @Jadzwin_ECUMASTER give an explanation on this?
As I understand it, 0% means no spark cuts at all.
100% means all spark events are cut (full spark cut).
Any value in between represents the percentage of ignition events that are skipped. For example:
20% means approximately every fifth ignition event is skipped.
For Launch Control in V3, this usually functions as a ‘soft limiter’. When the revs approach the target, the EMU begins to apply the set percentage of Spark Cut.
In latests firmware there is no cut % cobtrol.
You set RPM target and boost target and evntually RPM hysteresis. The ECU perform cut calculations to maintan the RPM target.
Can you please share any configuration of LC. It can be a simple config. Just want to counter check with my settings.
