LS3 Cam trigger
Hello
Currently wiring a LS3 58x and i woud like to know what are the settings for cam sync ? crank trigger is 60-2 afaik, ignition will be wasted spark as emu black does not have 8 ign output but id like to benefit sequential injection hence need cam trigger to work.
here whats the cam trigger looks like : ls2-cam-trig hosted at ImgBB — ImgBB
Second question : how can i be sure that injector will be firing at the correct phase and not 360° off? here how i configured my sparks and fuel outputs, is it right ? : ls3-ign-and-fuel hosted at ImgBB — ImgBB
ignition outputs are paired on the harness as wasted spark 1(1-6), 2(8-5), 3(7-4), 4(2-3)
