MAP as CAM signal
hi, is it possible to connect the signal from the MAP to the CAM input and set the CAM reading range between certain teeth to be able to synchronize the engine without a CAM sensor?
Yes. If you have ITB and MAP connected to the one intake runner. You connect it to the CAM sensor. You can also connect it temporary to Analog input 4 where the sampling rage is 250Hz to see the voltage drop during cranking. THen you need to select VR sensor with sensibility table as a CAM, choose falling edge, and in the voltage table set the voltage between max and min voltage from MAP sensor during cranking. Then set disable CAM sync above for example 400 RPMs. Works good.
