Map sensor load for naturally aspirated
on emu black using the onboard map for a naturally aspirated engine
should i change the y axis scale to say 20kpa to 110kpa instead of the 290kpa standard setting
or should i leave it “as is from factory ”
It should not differ really much if you tune it correctly. but having better resolation for ve always prefered.
thanks
ill go with more resolution
i didnt know if it would upset somthing if i changed it
just wanted to make sure :+1:
