Hi guys,
I have built a Pro base map with a stock development 96 Supra. Wide band sensors would normally be installed and configured, though we would like to be able to configure it with the stock knock sensors.
Lowering the knock signal gain to its lowest setting and using the 2nd harmonic still makes the signal upwards of 90% which does not appear to be very usable. Zach stated some of you have been able to make these work to successfully see relevant knock events.
Any advice with the Pro knock signal settings would be greatly appreciated using the stock sensors.
