Multiple simultaneous ignition outputs?
hey everyone, i searched for what i thought would be the correct terms already and did not come up with anything useful. on my toyota 7mgte it uses a stock ignitor setup that needs an ignition output from output 1 on every spark and an output from either 2 or 4 depending on the cylinders firing. on the V2 software the engine runs and this is what my ignition outputs look like.
on the V3 software either I am missing something or there is no way to select multiple ignition outputs to fire at the same time, so I dont have that signal going out on output 1 and as such i am not getting spark on 4/6 of my cylinders.
im a new user so i cant show what the v3 screen looks like
In the dropdown menu for choosing ignition outputs it only shows me 1 output available at a time. I would like to know if there is some work around in the software or if my best bet is simply to downgrade to V2 where I can select multiple. Or if this will be added in the future or there is some setting I missed in the menus. thanks
At this moment it is not possible to do that.
I think it is possible to add 7MGTE igniter support in next builds.
Other good option is just to skip the toyota igniter with multiplex and connect coils directly to the EMU.
Hello! Any update on this? Have the same issue using th 7mgte pnp adapter.
I haven’t received any news regarding an update adding the capability. I haven’t looked at update logs for V3 and have been living with the V2 software since my original post. I just now downloaded the latest V3 studio and I still do not have an option for ignition multi-output, so it looks like it’s still a work in progress feature.
