Need help setting up wastespark when missing an ignition output
Hi!
I have a Black ECU with a defective ignition output #1. I’m running this on a 6-cylinder engine with one ignition output per coil. Is it possible to configure it as wasted spark using only 3 outputs and logic coils? If so, how do I set this up in the software/client?
Thanks,
Henrik
Henrik,
you have to select the same ouput for event 1 and event 4
same output for event 2 and 5
same output for event 3 and 6
Normal firing order for a inline 6 cil is 1-5-3-6-2-4
So wire cil 1 and 6 together
2 and 5
3 and 4
Hi and thanks for answering.
Will this setup in the client be correct ?
According to the post above, your firing order is correct, but you’ve assigned the outputs incorrectly. You’ll want to match it to what the previous replier said.
OK , So like this ?
That looks right to me. At least according to the previous reply. I haven’t ever setup a 6 cyl. But that matches how I have my 4 cyl wired.
Just want to inform that this setup is working just fine.
