Hello everyone,
in the meantime I have continued working on the emu black. From using the original distributor to the current switch to WastedSparc, everything has worked flawlessly and the engine runs very well. However, injection is still semi-sequential, just like in the stock environment. Now, in test preparation for fully sequential injection, I’ve wired all injectors directly to the EMU outputs with a new cable harness and reassigned them under “Injectors-Phase.” The wasted sparc ignition was retained for the test. However, it didn’t work. Therefore, I’m not sure if a wasted sparc ignition with directly connected injectors is possible ? Or both, the ignition and injection must be operated fully sequentially ? I’ve included a hard copy for better understanding. Of course, I had changed the settings for the secondary trigger and injection angle control accordingly, deviating from the hard copy.
