Need help with throttle enrichments
Does this table look right for an SR20DET? When I click the ? it says it should be a higher value the faster the opening speed is. So is mine backwards? There is only 1 tuner near me and he did a very shit job tuning my engine so been trying to self tune and it’s been going good, but this is the table he made in my tune and I keep getting stumbling issues when I mash the throttle/stays lean longer than it should so I’m wondering if this is why?
With higher dTPS you need more enrichment then with low dTPS.
So table is the wrong way around now.
Are we positive? The base map ecu master has also does it this way
Yes I am sure:
Also in the help:
Yes, you have your original table backwards.
