New EMU PRO software version 220.1 beta
Updated EMU PRO software version 220.1-beta is now available.
What’s new:
  • Nitrous strategy improvements
  • Overrun strategy improvements
  • Improved DC motor control for EWG in Boost and Custom DC motor strategy
  • Cylinder head temperature sensor added
  • Wastegate temperature sensor added
  • PULS sensor can be used again as a source for the Oil Temperature sensor
  • Fixed the loading of an encrypted project onto a device locked with the same
    password without typing that password
  • Improvements to VW CAN streams:
    • PQ35 – Launch Control improved
    • MQB – Launch Control improved, brake pressure added
  • New secondary trigger:
    • “Signal level” for BMW N52
For the full list of changes, check out the changelog.
Download EMU PRO software version 220.1-beta today! http://www.ecumaster.com/testVersions.html
Sincerely,
The Ecumaster Team
Solved my two problems, thanks! PULS Oil temp works with oil level, I guess it’s ok they both pull from the same digital input? And the signal level worked great for the N52 (I had to select “Invert engine phase” but no biggie). Found sync on the opposite phase too!
Actually spoke too soon. I guess it will only start on the 2nd phase. I have a second plot that shows it skipping the first phase waiting for the signal level to be high.
I was just about sending message about overrun dbw settings… thanks for that
Yes! You are right.
It always starts with the phase that begins with a high signal level.
There is still one rotation that can be optimized in the future.
It would be nice if it was possible, in a future update, to add the switch function like ADU, to the project tree list. I would like to add some counters.
Really appreciate you guys adding the Cylinder head temperature sensor - thank you for that!
In firmware 225.0 (EMU PRO 225.0-beta), we extended support for the Signal Level secondary decoder; it can now start from either odd or even engine phase.
