New software 3.028 is available!
hi all so i have a few issues if some 1 can advise me please (car vw polo 1.8t 20v )
logbook faults dbw wbo map always come as faults ! if you start the car the engine warning lamp will come on for a few ± 3sec and go off because of the lambda .works fine in v2 .
since i changed to v3 some times the will start on the first swing and some times swing a few revolutions then it will idle .
also if someone can clearly explain to me the correct setings for EOI and the injector phase if they correct to use with 1.8t 20v 60-2 and cam 1.8t as you can see in the attced pic at 1 time the injecter showes 600*degs
Are you sure your injectors assignemt is ok ?
Also i would change cam 1 type.
To get good start select stary in watsed spark in igniton ouptuts parameters.
According sotred errors let me check it, as it can be an error in the software.
Please publish the log with the lambda error.
I have noticed the odd WBO error after first start and drive for a few minutes as well. this has only occurred since 3.028 but assumed it was specific to me. I have a log of it, I just have to grab the card out of my EDL-1 and upload. I’ll do that later today.
hi so the ecu is wired with a plug and play loom.
the injector outputs are 1 to1 (meaning out put 1 to injector 1 )
can you please explain what i need to change by the cam ? (1 type )
is the cam sensor related to the scope i posted that 1 injector is @600degs ?
attached is 2 logs and the project
20240618_0726 log driving eml on cold start.emublog3 (123.4 KB)
20240618_0745 driving log.emublog3 (1.6 MB)
20240618_1731_14.emub3 (58.0 KB)
look forward to hearing from you
Injectors assignement should be just like the coils:
According CAM type, it is ok.
According lambda error it is software bug, it will be fixed
