Hey, so I’ve set the map up and everything for the 3 cam sensor EJ. One of the signals go to the VSS input. In V2 we were able to reassign the the flex fuel input to a VSS input. So I guess my two questions are, does it default assign the vss signal to that cam sensor and also if I wanted to use the flex input for vss, how would I go about doing that?
Did you delete in the Log´s
“fuel pressure delta” ?
I can´t find them anymore
Dear Jadzwin,
I see problem with EDL on BT channel. Video by link
Video doesnt work ![]()
new link with video
Ok we will verify it
Thank you @Jadzwin_ECUMASTER
So is it my understanding there is no more error correction table?
It’s either closed loop from DC table or pid only?
My table is very well dialed to the point it needs very little. In v2 I only use error correction.
When setting up the range this makes sense.
Is there any ballpark pid settings you’d recommend to start with ?
Dear Jadzwin, 3.040 have the same problem with EDL
Yes I know. Next week tehre will be new EDL firwmare
