Parameter output for WMI
Im trying to copy my V2 data to the V3 and I cant find parametric outputs anywhere, so how can I control my WMI in V3 that I used to control with parametric in v2. I also controlled my cams with parametric output in V2.
functions doing that now
Okey, I need to look into it more then. Is the any guide for that?
Not yet, but it is very very similar to functions in ADU / PMU so you can refer to ADU manual right now:
From page 133
Regarding WMI, I use a switch associated with a function (Fn) to activate a PWM output to control the flow rate of the WMI pump. But would it be possible to have “injectors DC” on the PWM table in axis X or Y ?
Yes. Added to the list
