Peugeot 106 motore tu5
I’m setting up an ECUMaster EMU Black on a Peugeot TU engine.
Configuration:
  • Primary trigger: 60-2 crank wheel
  • Secondary trigger: single tooth cam sync
  • Full sequential ignition + injection
  • Crank sensor: 3-wire Hall sensor
  • Cam sensor: single tooth
Current settings:
  • Trigger angle: 114°
  • Primary wheel: 60-2
  • Cam sync pulse appears around crank tooth ~26 (counted after the missing tooth gap)
  • Trigger scope signal is clean and stable
Issue:
The engine almost starts, but I’m still getting occasional intake/exhaust backfires, which makes me think my crank/cam synchronization reference may still be incorrect.
Questions:
  1. How should EMU Black correctly determine cylinder #1 TDC compression with a 60-2 crank wheel + single tooth cam sync?
  2. Is trigger angle enough, or do I also need to configure cam phase/tooth position differently?
  3. Is there a recommended way to define the exact cam sync tooth reference relative to the missing tooth gap?
  4. On Peugeot TU engines, what trigger angle / tooth reference are others typically using?
I have clean trigger scope logs if needed.
Thanks.
Mine TU5 run with theses settings :
