PMU 16 Not connecting
Hi, I recently purchased an ECU-Master PMU16-DL together with the USBtoCAN module.
I have them wired up on bench as follows :-
  • +12v from PSU to Stud on PMU and to Pin 7 of PMU
  • Gnd from PSU to Pin 25 of PMU
  • CanHi connection from pin 23 of PMU to pin 2 of USBtoCAN
  • CANLo connection from Pin 36 of PMU to Pin 7 of USBtoCAN
  • Supplied USB cable from PC to USBtoCAN
Initially I get a solid green light on USBtoCAN
Power up the PMU and get a solid green light on the S Led of PMU – It stays on irrespective of CANBUS connection.
Start the PMU Client Software (version 121) and the Red Led on the USBtoCAN comes on, green Led flashes regularly and the amber Led flickers.
However the CAN1 status at the bottom of the screen remains “Disconnected” in Red.
Tried the Light Client too, nothing, also tried the Terminator switch on the USBtoCAN in both positions
The Red Led on the USBtoCan implies “Temporary CAN communication error” according to its documentation, but no further suggestions.
Any ideas ?
The CAN bus error can be generated by devices operating at different speeds on a single bus (not in your case, since you have one device and an interface).
Another source of errors is electrical problems. Missing, wrong, or swapped connections.
The most common mistake is swapping CAN high and CAN low on the DB-9 connector.
I thought the same on CAN Hi/Lo being incorrect, double checked and it was right. Even swapped them around despite being convinced I was right, it made no difference.
So no progress as yet…
I was wrong on the orientation of the CanBus Hi/Lo connections, the words were wrong, but the connection was right… So, Pin 36 is connected to Pin 2 of USBtoCAN for CanLo and Pin 23 is connected to pin 7 of USBtoCan for CanHi. But as I said before, I have tried both.
In the status bar of the PMU Client, apart from saying disconnected it also says “CAN1:passive ack” if that helps.
I did have one small success, I connected a Blink Marine keypad to the USBtoCAN and tried the Light Client, that worked fine so proved the USBtoCAN is working ok.
I am connecting the keypad and PMU seperatly, so they are not interfering with each other, also I do know they are running at different speeds which cannot be mixed on the same bus.
Cables are not very long, the CanBus is a twisted pair and about a meter long.
So still stumped on getting PMU talking. Any ideas anyone ?
Please make a picture of the wires coming out of the PMU connector.
Yellow wire is +12v (as is the connection to the stud ) , twisted black/white is canbus, black is CAN Hi, remaining black wire is Gnd.
Only other device on CANBUS is the USBtoCan, connected as previously mentioned.
status bar on PMU Client is showing this
Cheers
Looks ok.
Remove the connector and check whether the pins are pushed all the way into it. If they are not pushed all the way, they might not make contact with the device’s pin.
You can also measure voltage on floating CAN wires. Disconnect the PMU CAN wires from the rest of the bus. Measure the voltage between CAN high and ground. Do the same for CAN low. Both should be at around 2.5 V.
I am not home at the moment so will have another look later or tomorrow.
One question, is a common ground needed between USBtoCAN and PMU ?
At the moment it is not there, BlinkMarine worked without it, also my understanding of canbus is it should not be needed.
Ok, success but I am confused !
In order to be able to measure the voltage at the CANBUS pins on the PMU I figured I would power it up but without the connector in place. So I extracted the 4 contacts from the connector housing and carefully attached contacts to PMU pins directly.
I did not get as far as measuring any voltage, it just worked. It is communicating fine.
What is worrying is the contacts were definitely inserted fully into the connector and took a lot of fiddling to release.
Is there an issue with the plug/connector housing, it was definitely full inserted and the locking lever in place. Makes no sense. Anyone else with similar issues ?
Anyway, will have to experiment, maybe obtain another connector, anyone have a part numbers for the 39 way housing and contacts?
Cheers
Bob
Same exact issue. PMU16-DL + USBtoCAN, bench setup. Detailed
checks done:
  • M6 + pin 7 powered (12.5V verified to battery negative)
  • Pin 25 GND verified continuous to battery negative (multimeter
    beeps)
  • Green S-LED on PMU continuously lit
  • USBtoCAN green+amber blinking, red constant on, drivers OK
  • DB9 pin 7->PMU 23, DB9 pin 2->PMU 36 (continuity 0.005 Ω both)
  • Tried swapping CAN H/L — no change
  • Termination 60 Ω verified (USBtoCAN switch ON + external
    120 Ω at PMU end)
Measured floating CAN per your suggestion (USBtoCAN disconnected):
Pin 23 to GND: -4.5 V; reversing probes gives +3 V (not symmetric)
Pin 36 to GND: same behavior
Verified with two different multimeters.
The asymmetric values when reversing probes indicate the CAN pins
are floating, not actively driven by the transceiver.
PMU appears powered and awake (S-LED lit) but transceiver is
not initializing. Could this be a PMU shipped without firmware,
or a defective transceiver?
Try eliminating connector shell, extract contacts and insert on PMU pins directly, BE VERY CAREFUL OF SHORTS maybe some tape around the contacts.
Mine worked first time with this approach, I have been busy since so not had a chance to reintroduce the connector shell/housing. I would like to try another shell if anyone knows a part number, also for some more contacts so I can have a bench set up and a car set up too.
OK, this is weird, very puzzling.
I was able to prove I can get a good CANBUS connection if I remove the contacts from the connector housing and push them onto the PMU pins directly. I ordered another connector set and tried the contacts in the new housing, connection failed. Removed the contacts from the housing and insert on the pins again and it connects.
The contacts are reaching the end of the housing with a satisfying click as they find their retaining tang. The ground and +12v on Pin 7 work as the PMU powers up OK. It is just the CANBUS that fails.
What’s going on here, it seems very strange. Any ideas anyone…
Yeah, this makes no sense.
The only things I can imagine is that there is either no electrical connections, or a short circuit.
I would check for short circuits between CAN high, low, power, and ground.
With the device unpowered.
You can also compare the voltage measured on CAN high and low (in reference to ground), when using the connector shell and without to see if there is an actual, electrical difference.
This is a very unique problem.
First time seeing something like this.
Finally sorted this.
One contact, the Can Low one had spread. This means that out of the shell it connected because it was pull off centre by the wire, also it was push onto the pin deeper. When it was in the shell it was held by the shell and must have cleared the pin somehow. Anyway, closing the pin a little by pushing the tangs on its side inwards seems to have solved the issue.
I will not be using that contact in the vehicle, now I know, its getting cut off and binned.
I am guessing that the amount of contact that actually mates with the pin is not the full length of what is available once mounted in the shell.
Wonder if others have had issues with connections…
Glad you found the reason.
I know about a couple of cases like this, but they happened after people either pushed the multimeter probe into the terminal and spread the tabs or used a poking tool to push the terminal out.
Did you do something similar that might have spread the contact tabs in the terminal?
Well deduced my friend ! :confounded_face:
Never had any issues with this connector family (APTIV SICMA), neither with the supplied with ECU Master modules (PMU, Halfbridge ETC) or from other sources. We have used connectors and terminals bought direclty from Mouser but even from Aliexpress that depending on the reseller the quality is very questionable. Never had any issues at all. Did you tried to make a continuity test using a probe that may have caused that damage to the contact? Its the most common way to have this issue.
Edit: just read the mkuklis reply above stating the same as me about the multimeter probe :sweat_smile:
