Hi everyone, i have a question about CAN bus connection. How to connect the USB to can to PMU 16? How to create the CAN bus ring between emu black, pmu 16, adu, keyboard and USB to CAN? Thanks
You should start by reading the PMU Manual. Especially chapters 3.1, 3.2 and 3.3 https://www.ecumaster.com/files/PMU/PMU_Manual.pdf.
Ok, thanks for the help
yes. In the example you’ve highlighted the PMU is also powering the keypad.
The USB-to-CAN is bottom left connected to a laptop. It does not need 12V power, it gets power from the USB connection
Ok thanks for the help
