Using emu black as datalogger
Hi there, I have a ‘spare’ EMU black laying around that I want to use for datalogging on V3 software.
I need to connect the following sensors:
  • Vacuum sensor to measure underpressure at the oil pickup
  • differential pressure over an oil cooler
  • dry sump tank pressure
  • crankcase pressure
  • oil temperature
These can all be connected to analog inputs no problem, but I was wondering what frequency I can read them out on the laptop. (the vacuumsensor should be relatively high (above 100Hz)).
Thanks,
Mike
On V3 analog inputs are logged with 100Hz. The analog input #4 is logged 250Hz
