I’ve got a Classic currently running on my car. I am installing knock sensors and when checking wiring I noticed that pin B2 was already used. I traced the wiring and found it is the signal from the crank sensor. I moved the wire to pin B7 as per wiring diagram and now have no crank signal, if I return wire to pin B2 the crank signal returns and car runs.
Is there a way of testing pin B7 to check if the ECU is faulty?
refer to pin numbers on the drawing not what’s is written on the connector
yes, on the drawing. I checked to make sure I had reference correct against the known earth in pin 24 just in case I had wrong orientation.
To be clear its the black connector pin 7, B7
Thank you, I need to be more observant !
No worries, did that too when I was starting out.
Fairly common mistake to make
