I connected EDL logger in emu black, the green led kept turning on not flashing how can I edl logger save to SD CARD? What’s the problem?
yes i did but led green doesn’t flash
My problem is same as you said.
Is there any solution over that?
No I can’t solve it I looked at SD CARD there is save log but I don’t know why, That then I just looked at if it working properly
I have set Serial device as ECU master logger but it doesn’t blink fast and it Just flashing green led. I don’t how to solve it
You have the TX pin on the ECU side connected to the RX side of the EDL? Common mistake people make when wiring (myself included)
yes I did I Switched the line RX and TX and I solved the problem
