Car does not allow me to crank because of that error message. I can only crank the car currently via doing it directly from
The starter
The error posted before stops the signal getting to starter when using the key
I used this as a test to see if it would crank via the emu and a relay with the keypad. Which it does
Isnt the starter connected to OEM ECU ?
And what happens if you disconnect the gearbox connector ?
Starter goes via the bcm.
It won’t for example start if brake switch isn’t seen. (Brake switch is tested and working)
It thinks it’s not in park or neutral so won’t activate the starter)
I’ll try disconnecting the gearbox and come back to you
What about the gear selector ? Did you installed OEM gear selector ?
Worked fine with oem selector
Only since removing selector and using the keypad instead I have this issue
Could you publish your base map. It looks like a problem with the gear selector
My map I’m using is above that I posted yesterday
Could you please upgrade to V2 and set up selector emulation (even for rotary switch) just to check if it helps.
Yeah I can do that
I’ll come back to you
