Still busy with the setup on the Audi tt 3.2 turbo. With the plug & play Ecumaster black unit. So I got the map sensor right. Now it seems to be the dsg not working properly. When I put in in drive/sport it goes. But then disconnect and then all the selections of gears flashes on the dash… Can it be something with the can-bus? Can you help?
Dont know how to upload a video on this forum. If u have a email maybe then I can send it to you.
Regards
Jeff
I had the same issue on my Plug and play BUB ecu with my A3 8P VR6 DSG car. I had to add another 120ohm resistor to the canbus. I just ran it between Can-h and Can-L on the extra connector. Haven’t had a problem since.
Let me know if you need more clarification
Thank you for ur feedback.
The issue now is that the speed is not stable. It’s very erratic
This is the settings it’s on now.
This is my email where u can reach me quicker.
Jeffdamack@gmail.com
This is my configuration when I was on V2. never had issues.
I’m now running V3 configuration and have since swapped out the DSG for a 6speed Manual 02Q.
Ok. Thanks for that. I see i have my speed ratio set to 1.5
And ur one was set to 1
So maybe if a change mine to 1 my problems will be solved. Hopefully
So that I have to check on Monday.
But thanks for all the help. I also see u had an issue with the brake switch aswell. I also had that. But my tuner sorted that out. Don’t know what he did. But that’s sorted.
Would like to keep in contact with you…
Regards
Jeff
Problem is still there. Changed everything to what ur settings was. But still not working correctly. The speed jumps from 5km/h to 170km/h in the software. But the dash speed seems to be fine. And then also when in drive. It down shift by itself.
Is there anyway you could log on and check the map for me? We can use teamviewer or something.
My email : jeffdmack@gmail.com
Number : +27 82 965 4819 (WhatsApp)
Based in South Africa
