Using v3 (latest version)
Using a bub engine in 2011 scirocco mk3 so
Still pq platform
Mk5 r32 Dsg gearbox
Can keypad for gear shifter emulation
Cannot start the car as it says put the car in P or N on the dash.
Dash shows in P as does emu when looking at logging for Dsg
Holding brake pedal doesn’t make any difference, brake pedal shows as pressed ok in emu software
Anyone have any ideas? I don’t want to have to fit a oem shifter to resolve this ideally
When you install V3 3.047 there is a directory Base maps and base map for Audi R32 BUB
You can use it as reference.
I have used that and tried and still that message on the dash.
There could be a problem with the coding between your car and your DSG.
In VW car it is very tricky to swap components between cars.
However with black this message should prevent the engine from start and the gearbox from work.
Pretty sure it’s down to the car coding. Does the original ecu need to be connected to do a usb2can scan to get the coding? Is there any other way to find this as the car is already converted and wired with emu
You can try to power on the OEM ECU on the bench and just read the CAN.
However there could be coding conflict between DSG and the car.
I’ll try that. Thanks
Shouldn’t be any conflict as the Dsg was a option in the car also, it ran fine on standard ecu for the r32
So the DSG you have installed worked with the OEM ECU in this car ?
Yes r32 engine and gearbox worked fine with oem ecu.
Only with emu and trying to emulate shifter I’ve had issues
So if you have good coding it should work.
What are youre DSG settigns in EMU BLACK ?
What errors DSG reports via VCDS ?
I’ll check and post soon as I have time to get to the car
This is the fault in the Dsg box
Haven’t had time
To bench the ecu yet
r32.txt (2.4 MB)
scirocco.txt (1.2 MB)
Attached is the 2 trace files
Scirocco is a trace file from the original car ECU which i benched
R32 is a trace file from the engine and gearbox now in the car
tried changing settings in emu but had no luck with the issue still, coukld you maybe confirm what the can settings and gearbox settings should be in the emu please ?
Ben
Just to make sure. Did the gearbox work properly with the Scirocco ECU ?
Yes mate worked fine
Could you tell me what the correct coding should be from those files ?
Go to the menu/Tools, select option VW coding and select file scirocco.txt.
The following window appears:
As you press Yes it will automatically fill out the coding and other DSG options.
Will
Give that a go tomorrow if I get a chance and report back.
I’ve tried all combinations of the codes and still not working
Ok but why you cannot start the engine ?
Can you send a log from emu cranking ?
