Does anyone have a pinout for vw r32 crank sensor. Just want to check mine is correctly wired as currently not working since wiring in emu
Pins 1 -3
Ben
Pins 1 -3
Ben
to see if it works all you need is a magnet, it doesn’t need to be outside the engine block…just pass near and it should send the signal
This schema isn’t a bible but depend of motor code for ecu pin but is similar,i have the schema of dsg and leverage but I have to look in the files
I have those already was just trying to check
Which pin is sgnd which is signal ground etc
Thanks for them though
Yes i believe this is fine as it worked fine on oem ecu and all modules read fine
