R53 V3 starting help
I am having issues getting my r53 to start with the V3 beta. I have set everything up pretty similarly to the V2 map. I have tried everything. It tries to start, seems to be spraying fuel, and sparking it. Primary trigger is setup exactly as V2. I can provide maps to compare the two as well as starting logs for both maps. I may be overlooking something really dumb, so forgive as I’m still learning how this stuff works.
Post project, log and scope please
If it doesn’t allow you to upload it then try changing the data endings to .txt
R53 Map_V3.emub3 (66.7 KB)
20250408_1812.emublog3 (688.6 KB)
scope_202546_1740.emubscp3 (628 Bytes)
Here are setting that works for us:
Good afternoon. And why is that so? It’s not a mistake, is it? firing order: 1-4-2-3; injector phase: 1-3-4-2
all is ok. firing order is just offseted by 1 cylinder.
I’m pretty sure you are using a regular emu.
In case of PnP, it 's quite specific , for example the coil type should be “with built-in amplifier”.
I tried both emu, but I don’t know why their is a diff
Is there any advantage to disabling the cam sync after the engine has started?
You’ve added a 50us input delay in the new wizard. Does this replicate the V2 ‘Increase precision at high RPM’ option? And is the input delay affected by the input filter selected?
Disabling CAM is only useful when you have very noisy signal from CAM, especially on high revs.
It is beter not to enable this option.
Delay input is connected to all delays from the primary trigger sensor as well as output stages and spark generation. It doesnt matter at low RPM, however it can be notciable at high RPM (the ignition angle will retard a little proportional to RPM).
V3 has only high precision mode implemented.
Thanks… So 50us is generic or specific to the R53?
It is not generic value. Hower even you put 0 there there is no problem as you compensate it with VE table.
DaBlueOne, did you ever get it running with V3? I’m just getting started myself (1st post new), didn’t think I needed to be in the Beta game with zero knowledge. If you’re still around could you post your v2 Project, there are not a lot of us MINI owners out there, sure would help me.
I’m having a blast.
Unfortunately I no longer have my V2 map stored, it was for the most part the base map from ecumaster’s website. Just a few adjustments specific to what my setup is.
No worries mate, thanks for responding!
So, you get everything sorted out? I really just need to install the V3 client and see what the feature holds. @edues had commented on the assumption you had a Non-PNP variant of the EMU Black, was he correct? Curious because that’s the route I’m heading with my ‘06 R52.
Thanks DaBlueOne, enjoy your weekend.
Initially I did have the standard non-pnp black emu but I couldn’t find anyone in my area that was willing to help me with wiring. I am currently on the pnp one and on a V3 map
So it’s a PNP, got that cleared up.
Would mind posting current rev of your project, love to see what’s changed.
Thanks man!
Still love to have the current project file but the one attached has what I was looking for.
Who correctly configured Analog input 5 in your project? Have a buddy that has a PNP in his 53 and his was missing, base it’s missing.
Wow now I can resize the left panel, that alone is worth the price of admission.
I know the gauge would work if I put an oil pressure sensor. But is there a way I would be able to use the gauge on the cluster as a boost gauge?
