hi, starting to wire up the rb25 coils to the emu black ecu.
is this correct ? :
Nissan ignition coil, the ‘+’ pin is the
12V switched power supply, the ‘-’ pin is the signal wire that goes to the emu ecu to create a spark, and the ‘E’ pin is the ground / earth connection ?
see pic : rb25 coil — Postimages
This is correct,
+12V - +12v powers suppl
E - engine groun
_ - signal from the ECU
Those are the passive coils afair.
Artur
that is incorrect , just found ot the CORRECT pinouts. : + is switched +12v , - goes to ECU , E is ground to head.
My mistake, this is correct
E- goes to the cylinder head ground.
Artur
