RB25DET maf etc wiring?
when wiring up the emu ecu to the rb25det , does the MAF have to wired in , or can it be left out ? i take it the idle air , vct and cas still have to be wired to the emu ?
You should have an external IAT sensor feeding the EMU as well as use of the internal MAP sensor so you shouldn’t be using the stock MAF at all.
