Hi all,
Recently, as of a few weeks ago, the client will ask me to “use data from EMU or write new map” while cranking. Used to be that I would get asked that upon connecting and bringing up the client only. Now it asks for it as i load up AND, a second time while cranking. Not sure what to make of it. Any ideas?
Edit: ive been enjoying v3
Have you made wiring changes?
This sounds like the ECU is rebooting while cranking instead of staying powered up.
Maybe put a multi-meter on the ECU power source and watch while turning the key.
I have not. Its weird. Ill have to check wiring to see if anythings loose at the connector or whatever.
When i switch power it asks me ab9ut using emu data or client data. I choose emu. I start cranking qnd it asks again.
