20251109_1559.emublog3 (3.3 MB)
Little help needed Please .
The motor is 1jz non vvti . No dbw no Iacv Large forward facing intake and no clutch SW.
Black v3
Having issue just cant figure out . When I press in clutch the car sometimes stalls at idle . When I blip throttle and press in its worse DECEL . I have tried overrun enable disable not change . No fuel cut .Made changes to the ignition target Min Max and target witch did help a bit . Tried to pid changes from .P0264 i 0117 d 0 to p1.2 i .0498 d .5 with no minimal change . Confirmed no vac leak . The drop is from idle target 1050 to 650 ish RPM where it almost stalls .ON A GOOD NOTE .Through this process have learned that idle control is great on this software . Anyone with advice is deeply appreciated . Thank you See attached log.
