Hi everyone,
I’m currently having trouble getting my VANOS system to work properly on my setup, and I’m a bit stuck at this point.
I’m running EMU Classic and would really appreciate any help or guidance from those who have experience with a working VANOS configuration. If anyone is willing to share a base map or a map from a running setup, it would help me a lot to understand what I might be missing or doing wrong.
I can actuate the solenoids, and they are clearly audible. The VANOS can also be adjusted manually by applying power, so that part is working as well. That’s why I currently suspect it’s a software-related issue.
I didn’t create the software myself, so I’m now checking everything on my own since the company doesn’t have the time or interest to track down the problem. With a properly working software setup to compare against, I should be able to narrow down the issue much more effectively.
Hello there, I may have some interrogations on this subject and I’d be curious to check your map for my S50 build (stock with alpha N.) Could you send it to me as well? ( hedosfar@gmail.com )
