Save and Load calibration tables
v226.x
Saving the calibration table saves the axis channel w/ the table, this makes it difficult to use those tables for other sensors because unless the break points are linear or one of the preset exponentials, it just scales once the axis is setup to match the proper channel.
For example, using the same part number temp thermistor for 4 different inputs
  1. setup table from the calibration data (not linear break points)
  2. save table
  3. load table into the next sensor
  4. x axis still set for the saved table
  5. x axis wizard → looses granularity where necessary, towards the lower voltage ranges where accuracy is the most important
I suggest adding an option to pick the axis channel upon loading so loading the table comes in exactly as saved but with different axis channel
Yes, we are aware of this, and we have a solution on the to-do list.
We will bump the priority.
I don’t know if it needs to be a higher priority, it’s pretty easy to fix manually and once setup it doesn’t need to me messed with. Glad to hear it’s on the radar though! Thanks!
