I have a very unique situation that I’ve now had to deal with a couple times and looking for suggestion on how to deal with it.
We’ve had the unique situation where we have run 2 track configurations within the same session. This has come up on a few test days where the track will change configuration every 30 minutes depending on what different entrants want.
Our team was working on “Long Run” data and just had the driver switch configurations between laps.
So our Data has a Laptime and track map for one configuration, but not the other.
Is there a way to break out different laps within a session to provide times and maps?
This is indeed a very unique situation. At the moment, adding support for multiple track configurations within the same session would be quite complex and is not something we can deliver quickly, as we already have a lot on our to-do list.
That said, there is a workaround: if you do not use the Reference Track, the lap times should still be visible, as they will be based directly on the ADU lap times. You will also see the GPS trace for each lap.
You wouldn’t get section times in this case, but it might be a reasonable compromise for now.
Thanks, I figured this would be a 1 off issue as even the other teams were stopping, we were really the only ones that changed track config on the fly.
After looking at data a little, I found that using the Shorter track config would allow lap times for all laps.
