I have problems with the short term trim.
It works erratically and the tune display is not showing the target lambda.
It stays on a fixed value of 1.2 lambda.
Someone an idea?
porsche 2.4.emub3 (63.9 KB)
20251112_1636.emublog3 (293.5 KB)
I would say you need to start with your Acceleration enrichment settings. they are not correct. you are adding fuel at 0 tps rate. it seems to be playing havoc (for starters) with your fueling.
Thanks, its my first setup with an ecu master. What are the best acceleration enrichment settings to start with? I’ts all a little bit confusing the first time..
