Software opinions
Any plan of adding the needle sweep for the tacho and speedometer ?
what i want to archeve is lower power than my spring power (520hp)
this man xplains it better than me
Lets forge the rotary switch If this tables boost target is multiplied with boost by gear it can give me whatever power level i want in 1st gear for example 150hp(imposible to get this with Just my spring)
as everything now is modern is it passible to get another PWM output maps? total 3
I will taka look at the vide and let you know
No :frowning: there is no more PWM resources.
Hi Jadzwin, just wondering how the EWP implementation was going? Likely to see it in an upcoming update? Thanks so much for all your hard work!
It is planned for 3.045
Suggestion for Improvement:
Some people (including me) are using RealDash App as Dashboard and for datalogging. You’re also referring to this App for your bluetooth module.
Would be great if this log data would be accepted by Ecumaster black v3 client software. (Autotune)
RealDash dev would be willing also to implement your proprietary file format.
Using internal buzzer as a engine protection report high boost, afr, oil pressure etc possibly customizable.
I add an option to use a function foe activation internal buzzer.
Thanks for adding is there any guide to use function for using internal buzzer
Is it possible to add oil pressure based starting delay ?
can we get id names on user can bus? right now we have to memorize can bus id meaning
In regards to functions, I had a parametric output in V2 where I set an AUX out put high when cruise control was enable, It does not seen that there is any true/false state anymore for cruise is set and ON and NOT, therefore I cannot setup my indicator lamp for this anymore.
Maybe I am overseeing something otherwise I think it is a missing feature :slight_smile:
Arh sorry, my mistake, did not see that you state the values of each state in the function description.
Hi, I am trying to set up 8 injectors on 4 cylinders, but I found out that it is not possible with version 3. As an injection phase it is not possible and as a second line there is only bank1 and bank2. Can I use for example Fn11 Fn12 to open injector 7 and 8? Is the function fast enough?
It is very untypical application. Why you dont connect 2 injectors to one output ?
This is a standard connection, for example, with Pectel. I have two cars where I have the loom connected like this. With v2, it can be set in the Injector phase table. I wanted to switch to v3, but I would have to make a modification in the wiring, which is not possible.
Such situation wasnt considered. I will think if it is possible to add support for it.
Good morning, I have the problem that when I lightly press the throttle, the mixture briefly becomes lean. How can I prevent this? Should I change something in the parameters for acc enrichment?
And if I change something, what values should the numbers be?
[20250219_0640.emublog3|attachment]
(upload://bFCoEs9VRWJBFgcvcHr9Lfrq5S9.emublog3) (318.4 KB)
20250219_0640.emublog3 (318.4 KB)
