Subaru 36-2-2-2
I found your issue. You set up first trigger tooth to 30. The Subaru trigger is converted to multitooth 12 so during the full cycle there is 24 teeth.
Below there is a screenshot from the simulator with trigger tooth set to 1. All injection / ignition events are proper. With your settings I got the same results as on your scope
