i’m starting to go crazy. I’m having a sync problem and I can’t get the engine to start. After some digging, I found out that the Subaru 36-2-2-2 trigger pattern from the 4-cylinder engine is not the same as the 36-2-2-2 from the H6 engine — and I think that’s my problem. I couldn’t find any topic discussing this difference. Do I need to make a new trigger wheel?**
if you download v3 version there is trigger for both 36-2-2-2. it requires just differeny settings .
If you make a scope with v3 and start topic in V3 subforum I will help you
I don’t see the two option on the V3 i have the same issue
I found the configuration issue in your project:
