Toyota/Daihatsu cam trigger setup
Hi to all!
As a completely novice, i’m trying to set the proper cam trigger type to see if the vvti works.
You can find this type of trigger 3 teeth and 1 missing on Toyota and Daihatsu SZ,NZ,and K3 series.
Can anyone be so kind to put me in the right direction with the trigger setup?
Thank you in advance!!
Screenshot_20240722-234854
Seems like this is a ‘missing tooth’ pattern
Thank you for the reply.
But missing tooth isn’t more like audi’s trigger wheel?
My setup is very similare to 2zz toyota/lotus style
Someone suggested me to cut 2 theeth an keep only one tooth
