Dear community, Hi friends and tuners!
I am new here in the forum, I have bought an ECU Master Classic to run my VW 16v Turbo Engine.
I Build in the cable works, everything is installed and all sensors are alive now. Ignition is working and fuel Pump and distributors are flooding in.
I use a 60 - 2 trigger tooth Wheel. I have tested the top dead Center with timing light (sparks not screwed in for less pressure at the battery) and the Synchronisation is well done without trigger error. Now the problem: if I screw in the spark plugs and repeat the test procedure a trigger error appears: „unexpected missing tooth“ and I can See the failure in the scope as well. So the whole ignition timing is Not longer working and I can‘t start the Engine.
Fotos are Not allowed to Upload for me as new user
Does anybody know whats going on here?!
Best regards, Bastian
