Tunerview Bluetooth app
Hi guys
Since upgrading to V3 and the latest EDL-1 firmware the data shown is not correct when using the TunerView app, is this something that needs to be configured from within the V3 client or does the protocol that TunerView uses need to be changed to suit the new firmware?
Edit *Setup problem on my end, hadnt configured the serial for the edl-1, :person_facepalming:
Edit 2 no still the same with correct serial setup data is all wrong
Regards
Tim
Did you uprade EDL firmware to version 15 ?
Yes, updated to 1.15, this display is idling, TPS doesn’t change with throttle movement and it’s like the data is in the wrong positions
ok we will check it this week
There is a new EDL firmware (ver. 17) that fixes this issue.
