Turbosmart GenV Electronic HyperGate with Black
Has anyone used Turbosmarts GenV Electronic HyperGate45 with black V3. Which external driver did you use? Can the ECUmaster dual H-bridge power it?
Nobody’s using eWaste Gates?
You need dual h bridgefor it.. not possible use inbuilt h bridge
He’s asking about Ecumaster’s external H bridge driver, which can operate an E gate yes.
@Wtd I’d recommend using the Turbosmart Black Box. Works with Ecumaster and most importantly it’s calibrated to the E gates. You can actually get them stuck ramming the gate to full open or closed, they have also addressed the PID and position calibrations etc.
Thanks for your reply, much appreciated.
I used the black box with my turbosmart gate and EMU black, it’s extremely effective despite just using it with basic PMW solenoid control… I’ve moved to the Pro now and am going to see if I can run it via CAN but will still be using the black box.
