Trying to setup turn signals to my ADU 5 .Added inputd to A2 and A3. On the Analog Monitor checking for voltage I get 0 volts. Have missed a step? I added a 100k ohm resistor at 12v input. Thanks
You’ve posted in the wrong section, you want to be in the ADU section not EMU Black/Classic
Post the whole ADU file, I can barely read anything in that screen shot
Have you tested for 12V on the A2 and A3 wires with the turn signals on (using a multimeter) to function you have the correct wiring?
Thanks for letting me know I am in the wrong section. New member here. I was able to solve the problem with Andre Vaz from CWS wiring solutions. If I could move this post I would. Thanks Tony
