Good morning everyone
It’s the first time I’ve written in this forum,
because it’s the first time I’ve installed an Ecumaster and I’m in the planning phase, can someone kindly suggest to me how I can connect a twinspark system?
I have a Mercedes 550 AMG engine (113.986) with two separate twin coils per cylinder with a common connector (Bosch 0221 503 035), 3 wires, a positive and the two pilots, what should I do?
the customer has an EMU PRO 16, personally I would fit a Bosch 0 227 100 200 for each coil so as not to overload the driver, can anyone recommend something alternative?
thanks in advance to anyone who will answer
Alessandro
I asked a similar Question on Facebook. You could try directly controlling them from your PRO-16 since your ECU is a beast, otherwise you could use some external Amplifier for sure.Someone suggested me using only one spark plug from the two which i would not recommend
