USBtoCAN - Compatible software (CAN BUS SNIFFING AND LOGGING)
It’s possible to use third party softwares with ECU Master USBtoCAN? Like savvycan or similar tools to log / sniff into the CAN BUS? Lightclient is a good sw but doesn’t have the same capabilities.
MoTec UTC is very hand when used with CAN Utils. I would like to make a similar use of ECU Master tool.
No, we don’t have support for any third-party software.
We have an SDK for USBtoCAN, so if someone is willing to write support for one of the third-party software, we can share access to the SDK.
I see that Savvycan can load log files from PEAK. Trace file from Light Client is based on PEAK trace files. Did you try loading the file? It should be able to parse them.
Just tried using the peak setup but no success. Could you please share the SDK?
