Would it be possible to add user correction table to boost DC? I’m already using 4d for boost trim (haven’t tested yet), and I’m thinking about adding open loop DC error correction, but not sure I can combine that and boost trim in 1 table in project tree to get the result I want. Software is setup for closed loop using target pressure, but I don’t want to use CL until I get a handle on base DC. Margin is dangerous AF with this setup so I have it basically disabled with 100kpa above and below target. It would be nice to just be able to turn Margin off completely.
I would like this as well
To add gear depending boost dc correction.
I try to get it to work with 4D but as we cannot multiple table its way to much work.
Would like 2D table for correction.
