What exactly should I set this setting to when controlling DQ250?
I understand the torque map - you dyno your car, see how much torque you got at which RPM and then you fill the table with real torque values so that EcuMaster passes this data to DSG and DSG applies appropriate clutch pressure.
But what should I set VAG MDI torque to? Is that max torque my engine produces? Or should it equal max torque in my DSG tune?
