Voltage delay for CANTCU?
Hello!
The CANTCU DCT controller needs a 30-60 second delay after shutting off ignition voltage to keep the gearbox adaptations. Is it possible to make this function in Black V3? Tried searching the FB forum and the community, did not find anything. Would be nice to not use a time relay..
Use delayed turn off function. You can set how long the ecu stay powered when there is no voltage on ignition on input. Rememeber that battery input must be connected to the battery.
I guess this will keep the engine running? i just want an output to hold a relay for 30-60sec. example a function paramter for 15 volage. so i can put aux 1 true if 15 voltage is on and when 15 voltage is off it hold aux 1 for 30-60 sec.
Hi, no delayed turn off will shut the engine and just keep the ECU powered on. We often use this to run the water pump after the engine shuts down. Important part is that 12V permanent is connected to the battery, so it does not disappear after the ignition is turned off
So activate delayed turn off and use some aux with functions to trigger relay?
Maybe i can use main relay output?
The ecu will keep the main relay on during delayed turn off phase.
