Overrun fuel cut: Is there a way to delay the fuel cut?
Good morning!
I hope i described my question right. I would like to delay the overrun fuel cut beginning for lets say about 2 seconds or so.
Maybe i could solve it with the fuel cut decay rate? I just wonder, if i turn down the decay rate to let’s say 50%, is there a chance to run lean and damage the engine? Even when there is no load on the engine?
This for example is from another ECU:
grafik
Here you are able to delay the cut with “Init delay” and “Cut time” should be the same as “Overrun fuel cut decay rate” in the ECUMaster Software.
Thanks in advance!
no time delay option.
you could raise up “Fuel cut above RPM” and “FC resume” - to move window of FC.
or rase up under pressure.
Decay rate - regulary produce nice pops from exaust, i not like this
Hi!
It is possible to add delay for next build.
Already added to the list
Perfect, thanks!
Will the next build be V3 or have you planed another V2 build?
There will be next v2 builds.
In v3 overrun is a separate strategy. More information about overrun in V3 tommorow
is there also the option for a activation period. lets say i want it to burble for 3 seconds than to into fuel cut.
and does anyone have a setup for nice burble sound? i dont want a complete explosion out of my exhaust. just a bit of groallll like a 140i bwm :slight_smile:
