Volvo power steering CAN2 ADU
Please advise, I have a Volvo power steering that only runs on CAN 500 kbps, but my Emu Black runs on CAN 1Mbps with other units, how do I forward messages from CAN1 to CAN2 of the ADU where my steering is connected?
decrease to 500kbps, i bet you will not notice slower speed, unless you have something fixed 1mbps
I use ADU, Gear indicator, canswitchboard, canbus keyboard, gps at 1Mbps, will that be a problem?
But I wonder how to send the power steering message to CAN2?
Use lite client and enable powerstering on ecu ypu will see new frame .
And export that to can 2. Sipmle job
I will ask our engeneers to prepare sample project with counter and messages required to control Volvo EPS
Please find attached a ADU project where Volvo power steering support is implemented using ADU CAN output and tables.
Volvo_Power_Steering_ADU_FW120.1.adu (6.8 KB)
Thank you very much for the very fast action, the power steering works well :slight_smile:
Is there any data that the PS outputs? IE. Temps, speed, errors?
It seems that the pump sends back only alive status
Hey Jadzwin. I’ve been using this adu setup for a while now working great. I recently moved from the black to the pro, I see i can’t import the same settings to the pro seems it can’t do mixed endian. Best to then let the pro just send wheel speed to the adu and then have it control it?
